Problem in database connection i can't get on my site.
What site, what's the error?
Login or Billing issues? File a support ticket via: http://byethost.com/support.php
Free domain - Get yours today!
Recommended: cPanel Hosting -- Free Web Hosting
http://bandit188.mega-free-host.info/
Problem in Database Connection
This Website is powered by PostNuke
Web site powered by PostNuke ADODB database library PHP Scripting Language
Although this site is running the PostNuke software
it has no other connection to the PostNuke Developers.
Please refrain from sending messages about this site or its content
to the PostNuke team, the end will result in an ignored e-mail.
Hosted Free By MFH
also how do i change the bandit188 part?
You should confirm the information provided to the script is correct in the configuration file, namely that the hostname is not localhost but sqlXXX.example.com, your MySQL user is in the form of user_123456 and the database exists and is in the form of user_123456_database
where can i find the config file.
If you uploaded as default, config.php is in the html directory.
Find and check you have these setting correct:
Code:$pnconfig['dbhost'] = 'sql###.example.com'; $pnconfig['dbuname'] = 'user_123456'; $pnconfig['dbpass'] = 'your password'; $pnconfig['dbname'] = 'user_123456_dbname';
still the same error and everything correct.
Try changing your password via your control panel to the same one used now, see if its a sync issue.
Have you tried adding:
php_value display_errors on
to your htaccess file?
You should get a more informative error message.
Can we assume you created a database, then as per readme file: chmod both config.php and config-old.php 777 plus the pnTemp directory and its subdirectories also chmod 777 before installing. You then got a successful install message?
* Edit
Didn't see your post mtp (busy reading the above readme)
one was already made for me also my mate looked into this error fix
https://support.hostnuke.com/index.p...barticleid=268
but i cant even check it by the link they said use .
my mate said they will be able to setup your database to connect to your file
now he has more know how then me he makes very hard websites.
AHHH not it says not found man this is really messed up.
