+ Reply to Thread
Results 1 to 5 of 5
Thread: Ftp and manual wordpress 2.9.1 installation problem
  1. #1
    Question Ftp and manual wordpress 2.9.1 installation problem
    Hi, i've tried to install wordpress 2.9.1 version, and here is the procedure that i've followed:
    1)I've created a database
    2) I've modified with notepad, the file wp-config.php, i've inserted databasename, username,password and hostname
    3) i've copied from my hard drive "blog" folder to htdocs folder my wordpress 2.9.1 folder with filezilla ftp client
    4) I've launched the install.php script, from this location
    Code:
    http://sitename.com/blog/install.php
    and an error page shown up, that tell me the installation can be done because there are probabily some database problem
    5) I've checked in mysql database, and no mysql database was up...
    6) I've recreated a mysql database but after a log out there wasn't mysql databse
    Now if i create a database, after the logout, there isn't mysql database, and if i try to install the script, i've got the "database error"
    Thanks for your attention.
  2. #2
    Join Date
    Nov 2007
    Location
    127.0.0.1
    Default
    I understand that there's a current problem with sql113 server if your on that.
  3. #3
    Default
    Yes i'm on sql113 server
  4. #4
    Join Date
    Nov 2007
    Location
    127.0.0.1
  5. #5
    Default
    Ok the problem was related to mysql server problem, now it's working fine.
    Thanks ^^
+ Reply to Thread
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
